atmos speaker install
Discussion in 'Home Cinema Building DIY' started by kennydies, Jun 11, 2016.
  1. kennydies
    kennydies
    May 7, 2001
    191
    UK
    +4
    Hey there.
    I am finally going to get my new receiver which comes with Atmos.
    I am lucky that I have easy access to the loft above and speakers will take minutes to install.
    As part of ongoing improvements I am fully insulating the loft space with celotex which leads me onto the question.
    What affect if any will putting celotex above the speakers have, do I have to allow room above the speakers for air flow or does it not matter. If i do have to leave a gap what is the standard?
    Anyone have experience of good atmos speakers want to give a recommendation, they need to be flush in the ceiling?
    thanks
  2. Daz1969
    Daz1969
    Dec 27, 2009
    482
    Manchester
    +63
    You really need to box in the speakers in the loft space. This not only improves bass response but keeps out all the dust and rubbish too. I made mine from MDF and sealed around the edges with silicone, after that it doesn't matter which insulation is used.
    I've fitted B&W CCM382 which fit between the joists perfectly, like you i can get into my loft really easily
  3. kennydies
    kennydies
    May 7, 2001
    191
    UK
    +4
    did you literally make the box to be flush with the top of the joist?
  4. Daz1969
    Daz1969
    Dec 27, 2009
    482
    Manchester
    +63
    Yes that's it and sealed the edges with silicone to keep the dust out
