sjackson
I've been admiring the JBL SCS-8 speakers and how easy they look to mount for Atmos so I was thinking of doing similar with my DIYSG Volt 8's.
I found these brackets on Thomann and bought 4.
www.thomann.de
They look good. From my calculation you could build a box 225mm x 225mm x 200mm which would fit these brackets perfectly. It'll be a bit of a squeeze getting the Volt 8's in there and might have to use 12mm MDF, but it's possible. With these, the Atmos speakers can easily be mounted and aimed at MLP.
Just an FYI if anyone was thinking about building DIY Atmos speakers.
Stairville HL-x9 U-Bracket
Mounting Bracket For HL-x9 / HL-x90 LED floods, Ideal for installations or mounting stands
