Question Atmos screw in ceiling speakers ?
panman40
I'm asking this for a friend, are there any decent quality atmos ceiling speakers which just screw into a joist ?, Or anything similar that requires very little DIY skills to fit ?.
Thanks.
gibbsy
Any speaker can be used from the ceiling provided they are small and light enough and the Cambridge Minx would certainly fit that bill. Readily available from the likes of Richer Sounds.
Minx Series
panman40
Thanks chaps, those Min minx, can the brackets be screwed directly into a joist rather than using plugs ?,
Gasp3621
If using 4 different type of screws for wood that goes deep enough, should work. The speaker and bracket itself doesn´t weight much really. You can always ask from Cambridge Audio if in doubt.
Min Minx 12 - WEIGHT 0.75kg (1.65lbs) & brackets are some plastic ones. Longer screws for wood should do the trick.
gibbsy
My old Dad would fit every thing to the wall using the famous Penrhiwceiber Colliery screw.....a six inch nail. Actually screwing into the joist would be safer, don't do as Dad did.
John
I have mounted a 1kg Canton CD10 with an acrylic bookend and 3x command medium picture mounts.
The only holes I have made is to hide the cables
On the wall, not the ceiling, obviously
Graham
The minx min12s are so light that I don’t think your ceiling will struggle at all, and you won’t need more than the supplied bracket. Very easy to put up.
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
