Rob.Screene
I am planning a Dolby Atmos upgrade. I am currently running a 5.2 system with two big SVS subs in a converted garage.
I currently have some floorstander Linn Keilidh speakers as L+R
I also have another pair of Linn Keilidh floorstanders mounted upside down on the side walls as SL+SR, suitably behind the three seats. The leap to using the the same for front and back was huge, as is the bass control and impact of good sized cabinets.
I have read that upward firing Atmos height speakers don't work well because only treble finds it's way to the ceiling and back.
A complication I have is that I have a soundproofed ceiling, with a bedroom above the dedicated room. It is resiliant channel floating ceiling with two layers of soundboard, and the floor above floated on rubber "top hats" and sealed.
At the moment I can listen at -14db (below reference level) and still have my daughter drift off to sleep in the bedroom above. As you can imagine, I don't want to put any holes or mount speakers on the ceiling.
I am looking in to mounting two height speakers at the left and right wall tops, around 10 degrees in front of the the three chairs as-per the Atmos 5.2.2 recommendation angles. I also luckily bi-wired the surround speakers, so can easily split those to off to feed the two height speakers.
I am not likely to add front height speakers, as I didn't pre-wire the room for those and the equipment rack is at the back. Plus I have bass traps in the top of the front wall corners.
I am considering the Elac Debut A4, XTZ S2 or KEF R50 atmos speakers. These range between about £250 and £600 a pair.
I have also seen SVS Elevation Prime on wall speakers. I guess Q Acoustics do some great value speakers that can be wall mounted, but I assume that these being ported mad not work well with corner loading between the ceiling and wall.
I guess I need them angled downwards, so if the XTZ or KEFs can be safely mounted on the walls downward firing then it could work well.
Any thoughts or experience appreciated.
regards,
Rob.
regards,
Rob.
