Atmos connections
Discussion in 'Home Cinema Speakers' started by Wizzard, Jul 5, 2016.
Tags:
  1. Wizzard
    Wizzard
    Feb 27, 2005
    84
    Hi I am a newbie in the Dolby Atmos world! I have the new Onkyo NR656 AV receiver. I was thinking of getting the Onkyo Atmos add-ons to sit on top of my front speakers.
    My question is - where do I connect these speakers in the AV receiver? My current setup is 5.1 and have the option to go to 7.1. Do these connect to the 7.1 connectors?
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,529
    United Kingdom
    +2,096
    You'd connect them to the speaker terminals labelled 7 & 8 (Surround Back or Height). You would also need to go into the main setup menu and assign them as Height speakers as they can also be assigned as Surround Backs.
  3. Wizzard
    Wizzard
    Feb 27, 2005
    84
    Many thanks! I guessed but was not sure of the connections.
    Just curious - what would happen if I was using 7.1 already? Where would the connections go?
  4. Wizzard
    Wizzard
    Feb 27, 2005
    84
    Another point - I use 7 & 8 for Front speaker Bi-amping. I guess to use Atmos I need to remove Bi-amping?
  5. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,529
    United Kingdom
    +2,096
    In answer to both your questions. If you're using 7.1 already you'd have to drop back to 5.1 if you want to have Heights.
    Same goes for Bi-Amping, you'd have to give that up for Heights as well.
    The NR656 might have the possibility of increasing the available options if it has Pre-Outs so you can use an external poweramp. You'd need to check the owners manual for any info on that.
  6. Wizzard
    Wizzard
    Feb 27, 2005
    84
    Is it better to go for Atmos or Bi-amp?
  7. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,529
    United Kingdom
    +2,096
    Atmos does sound good if you're able to get the speakers positioned correctly. If not, you might be slightly underwhelmed.
    Are you able to borrow a pair of speakers to try it out?
  8. Wizzard
    Wizzard
    Feb 27, 2005
    84
    Unfortunately no.
  9. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,529
    United Kingdom
    +2,096
    Might be worth just running your front speakers normally rather than Bi-Amped to see if you think you'll miss the performance/sound. If you can live with them like that then I'd be tempted to dive in and try Atmos.
  10. Sy Hash
    Sy Hash
    May 16, 2017
    9
    Jeddah
    I live in an apartment. Would atmos reflecting speakers disturb the neibours on top. I mean, would the bouncing sound waves from the ceiling cause any vibrations to the floor up? or should I think of only overhead, direct speaker?
  11. mikemag
    mikemag
    Jun 5, 2007
    3,277
    167
    +7,743
    You'll be fine. The overhead effect is just that, an effect rather than a main channel like your fronts, and unless they've changed since I bought mine there's going to be nothing blasted out that'll create enough of a sound to disturb anyone on the floor above :)
  12. Sy Hash
    Sy Hash
    May 16, 2017
    9
    Jeddah
    Thanks mikemag, that cleared my apprehension.
  13. Roen
    Roen
    Apr 3, 2017
    72
    11
    NYC / T.O.
    +7
    [​IMG]
    3.1.2 setup.
    I ended up moving my upfiring speakers from on the bookshelf to near the bookshelf but lower. The greater effective distance seems to do wonders in generating a height image.
    I wish there was a visual way of aiming the bounce speaker.
  14. damo09
    damo09
    Nov 26, 2013
    2,583
    +387
