joner7777
Starts with a unused green patio 8M x 4M like this-
Kept size under local council guidelines .
Then a floor frame with levelling feet--
Then walls, insulation ,wiring
Rockwool 75mm insulation all over then wiring then 9mm ply sheets covered with 10mm foam sheet and suede stapled on them.
The joins in the sheets are then covered with varnished ply strips raised up by batons.
[/ATTACH]
Finishing off the inside , bar is made from converted kitchen units with solid worktops for the equipment rack as well.
The posters on the wall act as insulated drop down window blinds.
The black side curtains are remote so as for screen masking when I get to set it up.
DOF Realty simulator and aircon to me cool.
So there is a cinema made from the ground up in 2 months ,just week ends and a week off work to fit the walls.
I could have bought a premade log cabin but it would not have had provision to install insulation or the size I wanted and it is difficult to fit a vapour barrier.
This started as I was reading all the ideas about rooms and equipment on AV Forums,
Thank you.
