K
koko123
I'm new here and would appreciate any advice!
I have IscanHD+ and am very happy with it. But recently I bought a new 52" Philips full HDTV and was wondering if anybody can tell me anything about the ATLONA VIDEO SCALER W/ HDMI OUTPUT. MODEL: AT-LINE-PRO2. It's not expensive unit (about $600) and can do a lot of stuff at least according to the description.
Anybody reviewed or used this unit?
The Atlona AT-LINE-PRO2 is a great additional to your home-theater system. AT-LINE-PRO2 behaves as a switcher, and a HDTV scaler. This unit is able to output multiple resolutions which allows you to match native resolution on your TV or Projector. You can now use one device to connect your composite video, s-video, component video, VGA (PC) and HDMI sources to one HDMI output, and get the best possible video. Any input can can be up-scaled to a specified resolution up to 1080p. Analog audio from any of the sources will be digitized and encrypted in to the HDMI output, using one cable for audio and video. You would also have the ability of splitting your source audio to a digital coaxial (S/PDIF) output, and routing it though an audio receiver.
Features:
* Both digital and analog inputs are format converted and pixel re-scaled through the AT-LINE-PRO2. It outputs a range of formats and resolutions that will easily match the native resolution of your display to ensure highest picture quality.
* Composite, S-Video, Component, VGA, HDMI inputs
* Digital Audio Output, perfect for routing audio though an independent audio system.
* Supports PC RGB input up to WUXGA.
* Supports HDTV RGB/YPbPr/YCbCr up to 1080p.
* 50Hz/60Hz conversion, if the input is 50Hz or 60Hz, you would be able to manually select either one on the output, perfect for customers who have USA TV's in Europe or other way around(PAL/NTSC).
* HDCP Compliant
* Supports digital HD output up to 1080p. or PC output up to 1920x1200
* Dual high quality scaling engines.
* Dual 3-D motion video adaptive de-interlaces with adaptive edge- oriented adaptive algorithm for smooth low-angle edge.
* Automatic 3:2 pull-down & 2:2 pull-down detection and recovery.
* The Proprietary Advanced Color Engine technology gives:
* Brilliant and fresh color.
* Intensified contrast and details.
* Vivid skin tone.
* Sharp edge.
* Accurate and independent color control.
* 3D noise reduction.
* Operates through on-screen OSD menu control and remote control.
Inputs/Outputs:
* 1 x AV input ( 3-rca )
* 1 x S-video Input + analog Audio
* 1 x Component Video Input ( 3-RCA ) + Analog or Digital Audio
* 1 x RGB ( VGA ) Input + 3.5mm mini stereo audio input
* 1 x HDMI Input
* 1 x HDMI Output
* 1 x Digital Coax Output
Technical Specifications:
* Digital Video Amplifier Bandwidth: 1.65 Gbps
* Input DDC Signal: 5 volts p-p (TTL)
* Input Video Signal: 1.2 volts p-p
* Output/Input Resolutions: up to 1080p
* Inputs: Composite(w/audio), S-Video(w/audio), Component(w/audio), VGA(w/audio), HDMI(w/audio)
* Outputs: HDMI ( Video/Audio) or route Digital Audio though Digital Coaxial output
* RS232 Control Port (Download RS232 Commands)
* Power Supply: 5V DC ( universal 110/220v )
* Dimensions: 7"W x 1.3"H x 5"D
* Shipping Weight: 4lbs
Package Includes:
* Atlona AT-LINE-PRO2 Scaler Box.
* D-Sub (15-pin) Cable.
* 3 x RCA Cable (Composite Video + L/R Audio).
* Remote Controller
* 5V DC Power Supply Adaptor ( universal 110/220v)
* Operation Manual
Features:
* HDCP Compliant
* Vivid skin tone.
* Sharp edge.
Inputs/Outputs:
* 1 x HDMI Input
* 1 x HDMI Output
Package Includes:
* Remote Controller
* Operation Manual
