ATI's DVD player, AE100 and HTPC question
Discussion in 'Projectors, Screens & Video Processors' started by mattr, Mar 17, 2002.
  1. mattr
    mattr
    Mar 9, 2002
    339
    Near Camberley
    +19
    I know this is a daft question, but ... if I setup my Radeon with the 848x480 custom resolution is the DVD player (the one that ships with the Radeon in this case) going to automatically know this is a widescreen resolution and just expand the image appropriately ? I'd hate to think it just assumes everything is 4x3 so would end up shrinking the anamorphic DVD to 4x3 and then stretching that out to fill 848x480. There just aren't any "widescreen" setup options that I can find, even with DVD Genie.
    Ta,
    Matt
  2. Punce
    Punce
    Feb 5, 2002
    407
    The Shire, Wales
    +16
    You really need Powerstrip, with this program you can create your own resolutions (or copy ones that others have working). I've done this, using Li On's settings, and they're good.
    Found here
    I have a few queries about it as I've just got into it, but that's the start.
    Punce
