ATI8500 ok for non games HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by hendern88, Apr 4, 2005.
  1. hendern88
    hendern88
    Mar 6, 2005
    52
    Hi there
    Is the above card ok for a non games machine running TT2 and ffdshow with an XP2.8 ?
    I'm hoping the card will not impact image quality as its simply being used for the digital out and has 'reasonable' performance.....
    cheers
    Neil
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Hi.
    The 'power' of the card isn't important to an HTPC unless you're going to use VMR rendering and use controls such as Anisotropic Filtering and other tweaks. In a software-only processing mode, ie. not using hardware-assisted MPEG decoding, then the quality of the image is dependent on the rendering done by the Overlay device (Overlay is better on ATIs than VMR in the main).
    The 8500 is certainly okay in that regard from what I can recall, it certainly isn't 'bad'.
