ati radeon x600 pro 256mb question ?
Discussion in 'PC Gaming & Rigs' started by daiashthomas, Dec 5, 2004.
  1. daiashthomas
    daiashthomas
    Dec 5, 2004
    20
    Near Swansea
    how the hell do i get the video out to work on my tv
    thanks
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    have you installed the ati control panel?
  3. daiashthomas
    daiashthomas
    Dec 5, 2004
    20
    Near Swansea
    yes the panel is installed
    and i've got it working in some way
    but it's only displaying my wallpaper and even when i use it as a primary display i cant see the start bar or do much with it it's useless
    all i want to do is play movies on it and play games on it
    :smashin:
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    i think you might have to fart around with the settings a little, it might be set to the wrong resolution if you cant see all the toolbars etc.
  5. daiashthomas
    daiashthomas
    Dec 5, 2004
    20
    Near Swansea
    tried altering resolutions and refresh rates
  6. richgtfc
    richgtfc
    Feb 14, 2003
    129
    19
    Edinburgh
    It's not very straightforward for a CRT TV....mine looks rubbish on a Radeon 9600. Do a search in the Computer hardware & Home Cinema PCs section, there's loads of posts that sould help.
    Rich
  7. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Sounds like your TV is working as a second monitor, try selecting send to monitor x or something simialar. If you want it to show the same thing set it as cloned.
