ATI MCE Catalyst 5.9
Discussion in 'Microsoft Windows' started by evolution400, Sep 22, 2005.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
  2. monopole
    monopole
    Ahh, could this explain why quite a few of my DVDs (including all the ones I've made myself using nerovision express) appear as a smeared / pixelated mess under MCE yet play fine using Theatertek/VLC/iDVD/Stand alone DVD player?
    MCE is using the NVIDIA DVD decoder that came with Theatertek (which I bought long before I installed MCE).
  3. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Yes thats the exact problem I just change to the WINDVD codec to watch dvds if I have a problem but hopfully this will sort it out.
  4. monopole
    monopole
    That did the trick! Great stuff.
  5. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    I have installed these drivers it has fixed that issue and also appears to improve the picture quality aswell cant fault it :)
  6. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    anyone tried them with a powerstripped vga-scart rgb lead setup ??? think the 5.8 drivers caused all sorts of problems (never got round to upgrading myself ! :) ).?
  7. Spacecat
    Spacecat
    Apr 1, 2001
    2,874
    London
    +559
    I am doing exactly this , i did also manage to get it working on 5.8 as well. The picture quality in 5.9 is also a tad better as well and works fine for me, be careful of the WDM driver though if you are using a ATI 550 Pro card
  8. monopole
    monopole
    Sounds interesting... How did you make the SCART lead and what are your powerstrip settings?
  9. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
  10. chuckalicious
    chuckalicious
    Sep 15, 2004
    238
    +4
    Just installed them too. Only thing I found is I had to re-create the custom resolution for Powerstrip as it must have been removed when I uninstalled 5.8
    Other than that no problems.
  11. DaveP
    DaveP
    I tried this new release with my ATI 9200SE and I have had to un-install it. It caused BSOD twice. The actual screen was unreadable with the RHS appearing on the left and the white text was distorted beyond readable.
    The first time it crashed I had the new hardware found wizard start when I re-booted. It found the 9200SE again!
    Dave
  12. chuckalicious
    chuckalicious
    Sep 15, 2004
    238
    +4
    Yup, I had to uninstall as well. My screen broke up into pink, green and white blocks when I was watching live tv. It also crashed a few times with an ATI app being listed as the cause in Event Viewer.
    Back on 5.8 and all is well :)
  13. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Its been great on mine.
    What card fo you have chuck ?
    I have a Radeon 9600XT Ultimate.
