ATI HDTV Component adapter
Discussion in 'PC Gaming & Rigs' started by pmccurdy, Oct 20, 2004.
  1. pmccurdy
    pmccurdy
    Hello,
    Does anyone know where Im able to buy the ATI HDTV component adapter? Wanna hook up my 2nd system to my DLP TV
    http://www.ati.com/products/hdtvadapter/index.html
    It's meant for US ATI cards but Im sure someones sells it here?
    feckin PAL systems ...... always lack of high def in Europe .....
  2. RichMercer
    RichMercer
    I've tried to source this before too with no luck I'm afraid. Have you tried ebay?
    If you manage to get hold of one I'd be interested as I still want one.
  3. RichMercer
    RichMercer
    Man, that was quick. How about this?
    They ship worldwide and it's less than £20 which can't be bad. ;)
  4. thebigkung
    thebigkung
  5. RichMercer
    RichMercer
    I'm not sure if that one on Yahoo is an original ATI one though. There are a couple more on ebay here so if you don't win one there are more.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I had to import mine from the states . Check out the HTPC forum.
    I personally found the performance a bit lacklustre but it will depend on display type probably
  7. pmccurdy
    pmccurdy
    Brilliant !
    Cheers guys !
  8. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    i was looking at doing this, how mant have tried it and how well does it work? i have a ati radeon 9700 tx (128mb), will i need drivers or anything like that? can you tell that i am not that well up on computers :blush:
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Tried 1080i type resultions on my HS20 ....you can get it to work with powerstrip but whilst it seems to improve judder slightly its very soft compared with dvi.
    I dumped it and went back to dvi at 1:1 pixel map.
