Lanus
Last week i got a Force3D HD 2400Pro PCI-E Graphics Card and it will not upscale any video no matter what i do, it simply resizes the video to fullscreen by making the pixels bigger rather then upscaling with resampling. Ive tried the basic xvid codec install, ive tried K-Lite codec pack, and various media players like Media Player Classic, WinDVD, the standard WMP and they all do the same thing. All i can get is simple resized video without any upscaling/resampling taking place so edges are very jaggy. This is with all formats i have, xvid, mkv 264, wmv, dvds. The machine is a brand new install of XP SP3 and ive used various ATI Catalyst driver installs and every setting inside the Cat Control. I know its not the software build because i did the exact same install on an older machine with an ATI 7000 and its working with upscaling as normal. Ive had 3 ati cards now, a 7000, 7500 and 9700 Pro and they all upscale out of the box. The only way i can get upscaling is by using a specific players upscale function such as WinDVDs Tridemension or ffdshows resize.
As far as im aware upscaling has always been automatic in graphics cards over the last 10 years or more and with ATI you cant actually turn it off so if anyone knows of a switch which allows upscaling to be turned off and on, that would be the only thing that would show that the graphics card is working properly. The place i bought it from says that upscaling is a function of the player software and not the graphics chip but i dont believe thats true, can someone educate me on this?
I can work around it by forcing ffdshow to upscale everything using the resize filter but that doesnt fix a faulty graphics chip and obviously increases processor usage a lot. So can anyone give me some suggestions to prove that the graphics chip is at fault rather than user error? Put it this way, can anyone else play video through an ATI graphics card at fullscreen WITHOUT the video being properly upscaled with resampling as opposed to simply making the pixels bigger exactly like the zoom function in an image editor?
Please lend me a hand here guys, we all seen video on our computers and we can all see if its being resampled or not.
thx
thx
