ATI graphics - Powercolor
Discussion in 'PC Gaming & Rigs' started by DaveMartin, Oct 22, 2004.
  1. DaveMartin
    DaveMartin
    Hello, Ive recently bought a Radeon 9200SE graphics card and it wll not be detected by my computer (XP). I have checked and everything is compatible. Also, the computer and monitor will not even start load if the card is in. Is there a way to delete the one that may be on the motherboard so that it recognises this one...Please help!!
  2. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    if your board has onboard graphics go into the bios and disable it but if you have been using a card go into device manager and remove the old card and all of its drivers then put your card back in
  3. DaveMartin
    DaveMartin
    Thank you for your response. Ill give it a go.
    Cheers, Dave
