ATI DVI to Component dongle into CRT, does it work?
Discussion in 'Desktop & Laptop Computers Forum' started by Slinkoff, Mar 27, 2005.
  1. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    I've been searching the forums but haven't found much of a definitive answer so I have 2 questions that I'd be very grateful if someone could help me with please:
    I've got a Radeon 9600SE that, for PC case size reasons, I can only use the low profile bracket with, so I only have DVI output, no VGA. I want to connect to a Panny TX36PL32 CRT 100Hz TV that has component inputs for AV4.
    1. Has anyone had any experience with using ATI's DVD-Component dongle and connecting to a 100Hz CRT television? If so, what's the picture quality like and what overscan problems did you encounter?
    2. If it works, great. I only want to use MCE2005 as a PVR, I'm happy with my Denon prog. scan DVD player. However, I have to connect a prog. scan DVD via component as well so is there somekind of component input adapter/selector that will allow me to connect two component video sources into the single set of component inputs I have on my TV?
    Any help much appreciated.
    Slink
  2. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    I guess your TV will accept 480p/i over component? In which case it'll work, or at least it does on my JVC but that also accepts 1080i :)
    The picture quality is great and I think the drivers have software to allow you to manually tweak a mode to correct for overscan.
  3. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    Thanks for your response. It's good to know it does at least work for your CRT TV so there's hope for mine. The part's on order so I should know soon.
    I've no idea what my TV supports. All it says in the spec under Receiving Systems/Band name is:
    PAL I UHF E21 - 68
    PAL 525/60
    M.NTSC
    NTSC
    And the component input says it accepts normal interlace format as well as progressive format. Is this a good sign?
    Slink
  4. nathsea
    nathsea
    Apr 26, 2003
    917
    +24
    HI
    where do you get these dongles from?
    Many thanks
    nathan
  5. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
  6. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    Your TV sounds as if it'll be fine for 480i/p then :) The dongle doesn't support 576i/p so no PAL resolution support unfortunately, just NTSC. It is a nice solid picture though :)
