ATI DVI-I to Plasma DVI-D
Discussion in 'Cables & Switches' started by nohoper, Jan 23, 2005.
  1. nohoper
    nohoper
    Thanks for browsing. Any input would be appreciated. I am currently in dialogue with Samsung Technical support about my PC connection to the Plasma.
    I have the Samsung PS42V4S with DVI-D Input.
    I have the AT9600XT with DVI-I output.
    The DVI-I female connection from the ATI card has the four pins surrounding the single flat PIN and the Plasma does not have the four pins around the flat bit.
    Every site I have been to about cables does not do a DVI-I to DVI-D. Am i missing something here, or should a DVI-D to DVI-D just do the trick?
    If anyone else out there has their PC DVI going to their Plasma I would really appreciate knowing what cable you purchased for your setup?
    Thanks in advance
  2. Bruce1310
    Bruce1310
    Dec 7, 2004
    227
    19
    Aylesbury, Bucks
    Hi Nohoper
    As you are sending a digital signal a DVI-D to DVI-D cable should do the trick. The extra pins carries the analogue signal.
    Bruce
  3. nohoper
    nohoper
    Thanks Bruce,
    I am just trying to rule out blatant stupidity from my side at the moment.
  4. BlindBat
    BlindBat
    I too have the same telly and am tryin to connect the DVI-I from ATI on a Mac to DVI-D on the Samsung... ahhhhh please is there any more info on why DVI-D to DVI-D cables doesn't work!?
    This page here has DVI information for the PS42S4 (newer version of the V model) http://downloadcenter.samsung.com/content/MM/200212/um_ps42s4_start_eng_040614.html
    but I can't get anything from trying these out with DVI-D to DVI-D.
    Funniest part was Apple Store UK (and the smartest bod's in their "Genius Bar"!) have shamefully never even tried to connect a G5 to a Plasma TV using DVI - they only convert through to VGA (which the samsung doesn't have!)...
    any help/wisdom on this is greatly appreciated!
