Ati driver for Sony Vaio
Discussion in 'Computer Components' started by tonyk79, Feb 7, 2013.
  1. tonyk79
    tonyk79
    Feb 24, 2006
    1,348
    63
    +202
    Guys,
    Can anybody provide a link to a modded ati driver that will work with an ati 5470 gpu in a Sony Vaio laptop. I can't use the official one as it doesn't install due to awesome Sony wanting to provide the driver. The latest driver they have is 2010 and when emailed I,was told they had no other drivers releasing. The laptop is running windows 8 and the built in driver.
  2. cokker
    cokker
    Apr 30, 2008
    918
    46
    Norwich
    +118
    Guru3D guy asder00 mod the latest drivers when released, your going to need the 4th or 5th (32bit or 64bit) download link "AMD Catalyst Mobility".
    AMD Catalyst 13.1 (9.012.0 December 19) AMD Official WHQL - Guru3D.com Forums
    I use these on my Toshiba A4 llano laptop.
    EDIT: Just re-read the part about not installing again (whoops), did a bit of googling and to be honest, you might be out of luck. I formatted my Toshiba and installed everything as normal, you might be able to do the same.
