------Update----------
Just an update to this I went back to the Nvidia card - TV and HD content played OK just not as crisp as the ATI card. There was less flickering though. HD content didn't seem as smooth as ATI
So I bought a SSD then installed Windows 8 RTM plus Mediaportal 1.3A and everything is running so well. No more flickering (this happened to both cards) no more juddering on panning scenes (so far). I don't get the every once in a while stuttering in 720p and 1080p content!
Not sure if Nvidia has corrected the drivers (I installed the Win8 64bit which stated Win8 support) or Windows 8 has added some magic? So far so good and I love my HTPC again and I love Windows 8!
So since there were load of Olympic HD channels added and Media Center was not scanning channels correctly I went ahead and installed MediaPortal.
After install I had very jerky movement on some channels (mainly BBC Olympic HD channels). I checked the refresh rates etc tried different codecs (which actually disabled the TV plugin! and caused about an hour of me looking to find the TV option again)
Anyway I swapped over from my nvdia 210 to onboard ATI 4200HD (or 3200?)
now everything was running amazingly. But after about 20mins the colours went pink. So I found the solution which was to change pixel format to YCbCr 4:4:4 to RGB 4:4:4 (studio mode or Full) and then reboot.
It all worked and very well - colours, picture and panning in HD looked amazing! but then after standby the issue came back - checked settings and its back to YCbCr 4:4:4! This also happens after a restart.
I am on the latest ati drivers which by the looks of searches is not a good idea but has anyone else had this? I believe the problem stems from my not so great Sony TV (it cannot do 1:1 pixel mapping, so I have to scale and that seems to cause flickering every so often)
Thanks.
Thanks.
