ATI 550 Pro card loses video settings
Discussion in 'Microsoft Windows' started by Cyclone, Aug 24, 2005.
  1. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    I have a problem with the above card. All works fine, when I run the signal setup it picks up the signal from my Sky box via Composite and playback is then fine. I can quit media center, put the system into standby and resume, and all is ok. But, when I shut the PC down, and reboot, the live TV is set to RF (at least it looks like it) and I have to run the setup again to switch it back to Composite.
    Anyone have any ideas what is causing this ?
    I think I heard of this problem on 550 cards before, but not sure.
    I have updated the drivers from the supplied Sapphire ones to the latest ATI.
    Help :lease:
  2. meansizzler
    meansizzler
    May 11, 2005
    7,588
    104
    London
    +266
    Do you have an RF card connected to your tv tuner, should only be the composite, anway not sure on this, maybe a fresh install of windows will fix the problem
  3. Spacecat
    Spacecat
    Apr 1, 2001
    2,942
    London
    +610
    always does this im afraid , v good card otherwise
  4. Werner
    Werner
    http://www.avforums.com/forums/showthread.php?t=233332
    seems to be a rash of this going on...all the research I have done leads me to believe it is only the pal versions that are doing this...reverting to rf input after a reboot.
    cant find any solution...
    anybody????
  5. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    You mean all these cards do this ?? Can't believe every card is faulty. I'll keep searching for now......but other than this problem it does look like a great card.
    In answer to Meansizzler, no there is not an RF lead connected.
  6. Spacecat
    Spacecat
    Apr 1, 2001
    2,942
    London
    +610
    well mine does it , and lots of people say theres does as well, fortunately i rarely reboot
  7. Werner
    Werner
    I have had some contact today to let me know there is a new driver update for beginning september which corrects this issue for pal cards.
  8. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    Sounds good :) where did you hear this from ?
    I have now spent 2 whole evenings trying to sort this, even going through all registry changes when it switches video mode. But even changing the settings back in the registry to composite settings, it doesn't work....oh well, thought it was worth a go.
  9. Kraken
    Kraken
    I have the exact same problem with my Sapphire Theatrix 550 Pro.
    I found that you don't have to actually go through the entire TV setup process every reboot, you just have to start it. i.e., get past the banner that warns you that any current recording TV programs will be affected. At that point you can just cancel setup, and it will correctly go back to your usual input.
    Obviously a bug in MCE or the 550 drivers somewhere.
  10. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    Interesting, i'll have to try that.
    For now I put the system into hibernation, at least it cuts the noise out at night (until I get it moved into my new room).
    Hopefully new drivers will fix it though.
  11. meansizzler
    meansizzler
    May 11, 2005
    7,588
    104
    London
    +266
    Hybernation or Standby?, hmm..from what I understand is that Hybernation saves all the stuff you are running to the ram then switches off your PC, while Standy switches off the PC but provides power to the components your request...
    I take it if you use standby you will get the problem?,...sees silly to release a card which has a fault in a software...
  12. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    What you say about hibernation is correct, either way will prevent the card from losing it's settings though, but at the moment the PC is in my bedroom (just waiting for the builders to finish my garage conversion, then I can move it out of the bedrrom - wish they would hurry up !!!!!!). But as the PC is not very quiet (i'll sort that out later) I put it into hibernation for now.
    Does this only effect Sapphire cards ? and does anyone with a PAL Sapphire card not have this problem ???
  13. Kraken
    Kraken
    No, there's a post of the XPMCE forums. A guy with the powercolour 550 pro also has the same issue.
  14. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    I see there are new drivers out on the ATI website, not had a chance to try them yet, anybody else tried them to see if they cure this problem ?
  15. Spacecat
    Spacecat
    Apr 1, 2001
    2,942
    London
    +610
    actually they dont in my system in fact its worse
  16. Cyclone
    Cyclone
    May 23, 2005
    403
    28
    +44
    Strange, I installed them last night and so far all looks good :thumbsup: Only rebooted a couple of times, but it kept the settings without a problem.
  17. Kraken
    Kraken
    Mine seems to work great with the new drivers too, I've rebooted twice and it's worked fine both times.
