Atec AV37W XBox360 & Which Wall Bracket?
Discussion in 'Home Cinema Buying & Building' started by DrWatson, Mar 14, 2006.
  1. DrWatson
    DrWatson
    Feb 16, 2005
    33
    Hello
    Does anyone know if the wall bracket for the Atec av37w is a proprietary bracket or will the B-tech / Slimline range of brackets be Ok ?
    Despite emailing a couple of people at Atec, I have so far not received a reply...
    Also this set has 2 x Compononet inputs. Will I be able to hook up my XBOX 360 to this and display 720p?
    Thanks in advance.
  2. coolchrisyorks
    coolchrisyorks
    Oct 6, 2006
    235
    Barnsley
    +3
    Yes..I would like to know about a mount for this model. I have bought an AVF Nexus mount that will hold upto 61" apparantly! Just wondered if anyone knows if its compatible. Its Vesa mounting compliable....
