How many tubs of Atacama Atabites would I need to fill a pair of Atacama SE5 speaker stands? I presume one 9kg tub per stand would be sufficient?....anyone?
For the SE series stands then one tub for each stand is sufficient although there is space for more if necessary. If you are looking to put more than that in them then I would suggest looking at the R series stands which come with 4 tubs supplied with them as standard and are far more sturdy.
