thanks mark, been thinking about getting a NAS , but i need a stable 4K version, whatever i buy (and when, as i have so many upgrades) i want a really good 4k media player (not an issue at the moment due to lack of content) but just thinking for the future, this one i think doesnt tick that box.
"Wired transfer speeds using a single Ethernet connection ran close to the maximum of a gigabyte per second, meaning even full Blu-ray rips can be done in around half a minute and, when called upon by client devices, playback was near instantaneous."
Getting Bits and Bytes mixed up maybe?
Going by manufacturers specs, using smart switches so the NIC's are teamed, you're looking at a very optimistic 2.5 minutes for a 30GB Blu-ray.
Its not HDMI 2.0 , so not really worth much.there is another models this one is 4k and has memory upgrade up to 8gb Ram.
asustor AS6104T link is here ASUSTOR - Innovation Makes a Difference
Remember hardware is HDMI 1.4b only, which means you run UHD/4K movies at 30hz or lower.Do you think it's about the update (Kodi 16.0) and that this AS6102 would be as good then, or is it about the hardware (would be weird but never know)?
