Quantcast
ASUS Transformer Wi-Fi Problems
MysteryMan
I am having trouble connecting my TF01 to my home network, via wi-fi. The problem is that it just does not see the network.
I know there are 2 sides to this - the TF01 and the router and this is what is so confusing as......
  • I can connect the TF01 to other wi-fi routers I have (there are 2 others in the house)
  • I can connect other things to the router, such as an Android HTC mobile phone
It is just the combination of the TF01 and this router that is the problem. When I go into "Wireless & Networks" settings then the wi-fi network does not appear in the list.
Has anyone any ideas of what I can try? :confused::confused::confused::confused::confused:
jlm32
maybe you could change the wifi channel on the router worth a punt.
the wife has one & her's would not find my iphone when i switch my mifi on :(
never did solve it.
MysteryMan
Yabba Dabba Doooooooooooooooooooo!
Changing the channel to 6 (it was 13) has sorted it out and am now happily connecting.
Thanks for the tip
:smashin::smashin::smashin::smashin::smashin:
never did solve it.
