Quantcast
asus set up no sound
walrustitty
my system
asusm4a88td-m evo usb 3
amd phenom x6 1055t
xt3d Amd radeon 6950 1gb
Corsair H80 Liquid cooler
W D 1tb hdd
Windows 7 ultnate
OCZ mod x stream-pro 600 watt psu
Max Zero 8 fan Controller
Icute 120 case
On loading windows 7 (which i do once a month because am getting the money together for a keyed version in the spring) Ive been doing this since June all went well service pack 1 instailed so started to load my software
PCTV Nanostick T2 for freeveiw and NO sound throgh the Back audio jack this is conected to my HI-fi amp.Firstly i checked to out put settings on the desktop this said nothing plugin and i could ajust the setting .I have sound through the HDMI lead to the tv/moniter but the sound is crapi I've loaded the drivers from the cd for the graphics card but still the same outcome any idea's :facepalm:
thank you
Andy98765
In the bottom right hand of the screen right mouse click the speaker icon.
Go to playback devices and select the one you want. Should be speaker.
walrustitty
Done that my Friend in the playback box on the desktop it say's both, speckers & headphones are not plugin but this is not true. the lead works (pluged my mp3 player in to test)and this set up as worked perfectly since June?????
