ASUS P5W Mobo - Problems?
Spoonboy90
Has anyone got a ASUS P5W mobo? I've just put a system together but can't get any display out. Read that it could be a BIOS/CORE2DUO issue so got a P4 but still no luck, had the graphics card tested and thats ok (maybe not with this mobo)
If anyone has one of these mobos could you let me know what RAM and graphics cards you are using
Jamie
Andy98765
A. Does it actually power up?
B. Have you put in ALL the power cables as newer MBoards require two power cables, there is a little 4 pin job as well as the 20 or 24 pin power cable.
C. Assume you have not installed any form of software yet.
In the meantime I will take a look at the manual.
Spoonboy90
Everything is plugged in correctly, checked and triple checked everything.
It powers up, fans spin, drives spin when connected just no video out. after 60 seconds it turns itself off.
