ASUS P5KC Realtek audio not available
Discussion in 'Computer Components' started by marcofoo, Jan 30, 2009.
  1. marcofoo
    marcofoo
    Mar 3, 2007
    316
    +3
    I have an ASUS P5KC motherboard which has built in Realtek audio. I have however, been using a Soundblaster Audigy card also.
    I now wish to link up my pc to my Samsung soundsystem via optical cable. The Soundblaster card does not have optical output but the P5KC m-board does.
    I have tried removing the Soundblaster card and installed the relevant Realtek software, however the Realtek program does not show in Control Panel, Start menu, desktop, etc. once installed. None of the .exe files in the installation folder run either.
    Without the Realtek program I cannot switch between analogue and digital output.
    See posts 388-397 for more:
    http://www.avforums.com/forums/all-one-systems/754943-samsung-htz310r-home-cinema.html
    Many thanks in advance!
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
  3. marcofoo
    marcofoo
    Mar 3, 2007
    316
    +3
  4. jetinder
    jetinder
    Sep 16, 2006
    1,594
    63
    +139
    Uninstall all the drivers for the sound card and motherboard.
    Re-install all the drivers for the motherboard inc realtek that should fix it.
  5. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    you did enable the onboard sound in the motherboard bios?. :)
