Asus O!Play vs WDTV - which has better audio?
Cieran
I know this comparison between the 2 players has come up a few times now but I would like to know specifically which of them has the best quality audio?
The reason I ask is that I recently purchased a Sumvision Cylone 2+ which I thought was a great little product but unfortuantly I found the sound a bit lacking.
I was thinking of sending it back and getting either the O!play mini or WDTV mini (as i'm on a budget) but I want to make sure I don't make the same mistake again. I should point out that I don't have any fancy HiFi setup which I will run the player through - it's simply going into my TV via the standard RCA inputs.
Any advice or feedback would be greatly appreciated.
Many thanks!
Cieran
It sounds a bit bassy, muddy and undefined. I've ended up using a Fiio heaphone amp to make it sound a bit better when listening with heaphones.
I'm sure if I had a decent AV receiver or home theatre setup I could tweak it and get it to sound better but unfortuantly I don't.
Cieran
It's with anything I play - down mixing or not. I've ordered a O!Play which should be arriving tomorrow so I should be able to compare the audio output between the 2.
