Asus M2nPV-Vm SPDIF output help
Discussion in 'Microsoft Windows' started by iendicott, Aug 6, 2006.
  1. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    I have bought the above SPDIF module that plugs into the motherboard and sits at the back of the case. It has a Coxial and optical output. I have a coxial connector into a dolby amp.
    Now with the software you get with the asus motherboard you can setup 5.1 via the analogue connectors on the motherboard but there is no provision for just outputting to the SPDIF, however WinDVD platinum can output via an external SPDIF which works no problems.
    Does anyone have this motherboard with the SPDIF module working in windows so windows outputs in 5.1 and just not stereo ?
    Thanks Ivan
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi Ivan,
    I have the A8N-VM CSM which is the predecessor to yours and have the same design. I'm using the Pure Video Decoder in order to select SPDIF pass thru to my Dolby amp.
    HTH,
    Richie.
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    I have this motherboard with the SPDIF widget. In the ASUS utility you just ensure that Disable Digital Output is not set. It sounds like you have it correctly set up as WinDVD is outputting 5.1 The card just passes the bit stream to amplifier which decodes to 5.1 if it is Dolby Digital or DTS otherwise it will be stereo PCM. Windows sounds are only stereo. You need to setup 5.1 in MCE but it will only output DD 5.1 if the source e.g. a DVD is DD 5.1
  4. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    Nigel sounds about right but every time I run up a DVD I have to manually tell the software to output 5.1 to the SPDIF connector as it defaults to stereo output only. Anything I am not doing right ?
  5. lochindaal
    lochindaal
    Nov 21, 2003
    138
    There was a similar issue with the previous board and it required a registry hack to force 5.1 or else it defaulted back to stereo.
    Do a search in this forum and you should find it
  6. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    Cheers bud !
  7. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
  8. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
  9. nickwild
    nickwild
    Feb 2, 2004
    74
    Holmfirth
    Where did you get your spdif module from... I can't seem to find anyone who stocks it.
    Nick
  10. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    www.mediapc.tv one of the forum sponsors.
  11. nickwild
    nickwild
    Feb 2, 2004
    74
    Holmfirth
    Thanks Nigel:smashin:
