Asus Eee PC901 Utility (WinXP)
Discussion in 'Desktop & Laptop Computers Forum' started by yetanotherbob, Feb 9, 2009.
  1. yetanotherbob
    yetanotherbob
    Mar 22, 2007
    637
    28
    London
    +55
    Apologies if this has been posted before but I though It might come in useful for fellow users.
    I'm pretty sure that most of us, even after pruning/cleaning and endeavouring to install only on the D; drive, find that there still isn't a lot of room left on the C drive on the standard WinXP PC901
    Heres a PC901 utility from ASUS (AutoC2D) that automatically:
    Sets up drive D as the default path for the Program Files folder
    Transfers the Program Files folder and it's comtents in drive C to drive D .
    And after the AutoC2D activation finishes, the C:/Program Files
    becomes a soft link, which synchronizes with D:/Program Files.
    Software will be installed ONLY in D:/Program Files and will
    ONLY take space in drive D even if you select C:/Program Files
    as the installation path.
    It increased my free space on C from 670'ish MB to approx. 1.5GB
    Heres the link page for AutoC2D (You will find it under utilities and full instructions and the description summarised above are included)
    http://support.asus.com/download/download.aspx?model=Eee PC 901/XP&os=17&SLanguage=en-us
    Bob
