Asus CVM SPdif Volume level
JonLeach
Hi all.
i have looked all over the internet for ths one and cant find a solution,
i have the above mobo and used on board spdif out. By Default the WAVE volume is set half way on boot up, this is causing quiet TV as the SPDIF out uses WAVE volume to set the output, set it to max no problem. i use the remote to control my pre's volume so i cant use one of the freeware programs to set wave volume when changing the spaker volume.
is there a reg key somewhere to set wave devices to max volume on start up? i also looked at a registry change software but could not get it to change the start up wave level
Jon
iendicott
JonLeach
no
tried that i dont change the volume on the mce pc. that would help if someone has spdif and want to control the volume with the mce pc and remote.
my volume is controlled by the pre
Cheers anyway
Jon
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
