Asus A8N-SLI Deluxe & Heatsink ZM-NB32J
Discussion in 'Desktop & Laptop Computers Forum' started by DLPMaybe, Jun 10, 2005.
  1. DLPMaybe
    DLPMaybe
    Mar 16, 2005
    929
    +50
    Has anybody installed the Heatsink ZM-NB32J on the Asus A8N-SLI Deluxe motherboard?
    Or in fact any heatsink on that motherboard? It looks relatively easy to fit. My main concern is how easy is it to remove the existing fan.
    If somebody has gone through this process and can give an idea of how easy it to do I would appricate it.
  2. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
    I have fitted a ZM-NB47J to an Asus A8V-E Deluxe. The Zalman was not very flat, so it needed lapping. Apart from that it took about 5 mins to fit. Don't try it if the board is mounted, not so easy.
  3. betamac
    betamac
    I also fit it without any problems or alterations
    As long as you take it easy should be nothing to worry about
