Asus A7 266-E Motherboard and XP2500 Upgrade
Discussion in 'Computer Components' started by sapper, Aug 17, 2004.
  1. sapper
    sapper
    Jul 20, 2000
    2,258
    Southgate, North London
    +145
    Just a quick question, does this motherboard support an AMD Athlon2500XP CPU?
    Would I benefict much from upgrading the 1900XP processor thats already installed and working in the PC (from MESH)?
    If I was to change the CPU, would I have to change anyhting else?
    Adrian
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    I assume you have the a7V 266-e board, which only supports processors up to 266mhz bus, unfortunately the 2500XP barton is a 333Mhz chip. I think the highest Thoroughbred core available at 266Mhz is the 2400XP chip, and you may need a bios update to run that one. Check on the Asus website :)
