Astro A50 Gaming Gen 3 PC or Xbox SX
DarrenG
Been searching the net for this issue I have. I want to use the Gaming headset on my PC and Xbox Series X but not at the same time.
So if I want to use the headset on the PC I have remove the USB from the xbox and put in PC, then switch the button on the base station from xbox mode to PC mode. Obviously I reverse the procedure if I want to use the head set on the xbox.
Ideally I would just want to switch between xbox and PC by just using the switch on the Astro base station.
I bought a USB 2.0 A Male Plug to 2 Dual USB A Female Jack Y Splitter, Type A Female to Female Adapter USB Cable Coupler and 2 Type A Male to Male cables.
So I connected everything up in the following way:
Base Station > Micro USB to A Male > Type A Female to Female > USB Y Splitter > 1x USB Male To PC and another USB cable to the xbox.
Xbox seems to work OK, But the PC my Astros do not register when I put the base station into PC mode.
I can keep on removing the USB each time I want to play on a specific device but I'm worried that over time the USB connections will come loose.
Is there another way around this?
Darren
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
