loftie12
New A40s + Mixamp Gen4 all set up for my PS5 last night.
I've set everything up as directed (using TV optical as apposed to buying the adapter) but in Dolby mode on the mix amp nearly everything sounds echoed?
I say nearly as when testing on warzone (main reason I got them) in game menu, moving across or selecting different menus there is an echo, my character footsteps, weapon reload and other direct sounds are echoed, yet sounds around me (air strikes, ambient sounds) seem to sound fine?
My Samsung TV settings are as follows:
Select speaker = Audio Out/Optical
HDMI Audio Format = Bitstream (options are PCM or Bitstream)
Audio Format = Dolby Digital (options are PCM, Dolby Digital or DTS Neo 2:5)
(HDMI cables and optical cable are all connected to what is called a SAMSUNG ONE BOX which then has a cable which connects to the TV)
PS5 settings are:
Output device = USB Headset (Astro Mixamp pro)
HDMI device = AV amplifier
Number of channels = 5.1
Output to headphones = chat audio
Audio format (priority) = Dolby
NOTE: 3D Audio on or off makes no difference.
Any help as to why it's echoing?
PS5 settings are:
