Astra Sat Direction
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Beaker, Jan 18, 2009.
Tags:
  1. Beaker
    Beaker
    May 4, 2002
    96
    11
    York
    +7
    The Astra sats are at 28.2 East. Ok, so is that 28.2 degrees past East on a compass (73.2 degrees from North). Most people suggest it should point nearly south would that mean 28.2 degrees towards east from south (151.8 degrees from north). I'm trying to work out the best site to fit my dish.
  2. derek500
    derek500
    Dec 23, 2007
    3,714
    103
    +491
    It's east of south.
  3. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,170
    Redditch
    +4,107
  4. CanaryPhil
    CanaryPhil
    Aug 28, 2008
    67
    Norwich
    +14
    28.2 E is not a compass bearing, but a point over the equator at Longitude 28.2E. The actual bearing will depend on your location.
  5. asibley
    asibley
    Oct 23, 2004
    +9
    Found this great website the other day.
    SES ASTRA - Installation assistant
    Gets you sorted for the astra sats. Takes into account any obstructions that may cause you problems too.
