Astell & Kern Sr15 to Hi-Fi
hamlynrudd
Hi everybody,
I have just purchased myself a second hand A&K SR15. I would like to connect this to my Arcam amp to play lossless tracks through my hi-fi.
What is the best way to do this? Is it simply to connect the Sr15 to the amp using the standard 3.5mm jack?
Any help would be gratefully received.
P. S. Has anybody found a good alternative to the official protective case for the SR15, as they are so pricey?
Thanks again.
Steven
Senior Moderator
Yes, just select line output "on" in the menu
The player also supports USB digital out provided the DAC being connected has USB input
hamlynrudd
That's brilliant, thank you. Also, is it also possible to connect this to a Chromecast Audio, or would that deminish the sound quality? Thank you.
Steven
Senior Moderator
A lot of the daps use older Android so may not even allow you to install Google Home app, although you could try
A likely better option is to use the SR15 Bluetooth to connect to say Bluetooth speakers
