Assistance with connectivity please!!
Discussion in 'LCD & LED LCD TVs Forum' started by oobster, Oct 31, 2005.
Tags:
  1. oobster
    oobster
    Oct 25, 2005
    90
    +5
    Some set-up advise for a newbie :lease:
    I currently have Sky+, a PS2 and a VCR connected my my 28" CRT Sony. Somewhere in the loop is a SCART to red-and-white RCA cable, which is plugged into the AUX IN of my Sony micro hi-fi.
    I am 99% sure that i'm going to order a 37WLT58 tomorrow, along with a SD-350 DVD player.
    I shall be purchasing a decent 1.5M scart cable to connect the new TV to the Sky+, and the new DVD player will be connected via new component cables. The video (which is rarely used) will probably go thru an existing cheap scart cable.
    My question is:
    1) How should i connect my PS2? It's going thru the AV3 setting on my current Sony, which is the red-white-yellow RCA cables on the front of the set.
    2) How will i re-connect everything so the sound still outputs through my hifi? The micro-hifi will hopefully be replaced in the next 3-6 months with separates, but at the moment i'd like everything (DVD, VCR, PS2, Sky+, LCD) outputing thru the hifi.
    Many thanks in advance for all replies - much appreciated
    oobster
  2. oobster
    oobster
    Oct 25, 2005
    90
    +5
    bttt
  3. oobster
    oobster
    Oct 25, 2005
    90
    +5
    C'mon folks - help a newbie out here!!
  4. areuwithmee
    areuwithmee
    Get rid of the ps2
  5. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    Looking at the Toshiba Site connections web page for the 37WLT58 I would put Sky+ on the First SCART socket which is RGB enabled (and enable your SKY+ to output a RGB signal) and then buy a PS2 RGB SCART cable and plug that into SCART 2 (RGB) (Most Game, Gamestation, HMV etc shops sell these PS2 Cables and enable RGB output on the PS2) and then put your video with the cheap SCART cable into the SCART 3 socket.
    And buy a phono cable (male-2-male (red-and-white RCA cable)) to plug into the bottom Audio Output Sockets (L/R) of the 37WLT58 and then plug the other end of the cable into your Micro Hifi.
    And if you are using the DVD PLayer with the component cables you will also need another phono cable (male-2-male) cable to plug into the DVD Player and the other end into the component conections area where the L&R Audio sockets are.
    This should hopefully allow all the sound to output via your Micro Hifi till you get your seperates.
  6. oobster
    oobster
    Oct 25, 2005
    90
    +5
    Many thanks for your reply yonderblue :)
