Aspect Ratio selection on a 504HDE
Discussion in 'Plasma TVs Forum' started by jfraser, Jan 4, 2004.
  1. jfraser
    jfraser
    I'm confused by the instruction manual....If I'm watching an anamorphic movie, should the display be set to 'Full'. For general satellite viewing, should it be set to 'wide' or 'full'. The manual refers to 'squeeze' pictures....what's a 'squeeze pic'......, also is a 14:9 image 2.35:1 aspect ratio (is this letterbox). Thanks.
    Sorry, one final question....when I set the 868avi output to 1080i via hdmi and the screen locks to 'Full', will that always give the most accurate aspect representation of the movie regardless of whether it is 1.78:1 or 2.35:1 etc.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    Full is the correct setting, assuming that your sky box is set to 16:9 display. Also correct if your DVD is set to 16:9.
    14:9 would be used for viewing a 4:3 broadcast thet has black bands top and bottom (eg. from your media box terrestrial signal)
    2.35:1 is the very wide cinema format that most films are mastered in, and would normally be DVD which you would watch in FULL mode.
    Clear as mud eh?
  3. jfraser
    jfraser
    Thanks for the info
    Jason
