Aspect ratio OSD - How to I cancel it
Discussion in 'TVs' started by Kendo, Apr 1, 2003.
  1. Kendo
    Kendo
    Sep 15, 2002
    37
    9
    Edinburgh
    Can anyone help me please!!
    This is doing my head in.
    I cannot get rid of the osd in the top righ hand corner of the screen that is telling me the aspect ratio currently in use. ie 16:9
    I have a Sanyo TV and my DVD is connected RGB Scart.
    I have the service manual, but I dont know what I should be looking for.
    Any help would be appreciated before I launch the remote through the screen!!!!!
  2. Squirrel God
    Squirrel God
    I'm not familiar with Sanyo TVs but a model number would be useful.
    By service manual, I take it you mean user manual? Anyway, if you mean that the screen mode shows up all the time, then try turning it off by pressing whatever button on the remote displays 'info', or by holding it down for 15-20 secs...
    If you mean it just comes up briefly whenever the screen mode changes, then I doubt there's anything you can do about that. My Sony TV does the same and it can't be turned off. Can't say I've ever found it annoying though.
  3. Kendo
    Kendo
    Sep 15, 2002
    37
    9
    Edinburgh
    Hi Squirrel God
    Thanks for replying
    The display is on permanently.
    The television is a Sanyo 28WN3
    And I have the engineers manual
    Kendo
  4. nathan_silly
    nathan_silly
    Some TV's (Sony's) have a display icon button. Pressing it once shows the current channel in the top-right, and it stays there.
    Similar to yours? Press every single button on the remote, it might disappear...
  5. Kendo
    Kendo
    Sep 15, 2002
    37
    9
    Edinburgh
    Ive tried that Nathan but it doesnt work
    thanks anyway
  6. nathan_silly
    nathan_silly
    Is there a reset somewhere in the TV menu's? That should delete all channels, contrast/brightness settings, and hopefully remove that icon.
    You'll need to re-tune the channels, no big deal.
  7. Kendo
    Kendo
    Sep 15, 2002
    37
    9
    Edinburgh
    nathan
    ill have a look and see
  8. Kendo
    Kendo
    Sep 15, 2002
    37
    9
    Edinburgh
    Hi Nathan
    Unfortunately I can find no reset functon.
    Serves me right for buying a Sanyo I guess!!!
