Aspect Ratio on RD-XS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by the_Geezer, Jan 14, 2005.
  1. the_Geezer
    the_Geezer
    Aug 12, 2004
    461
    +26
    I recorded JAKE 2.0 on the Tos RD-XS32 HDD from sky one which plays great on my TV with the auto 16.9 then back to 4.3 when the adds come.
    The problem is when I go to DVD-VIDEO CREATION and add the Jake file with the adds edited out so its all 16.9 picture this is what comes up in a window .
    Selection of pre-writing test in the next option setting is recommended to check whether aspect ratio coexists
    Tried this and the dvd come out in 4.3 cropped then I tried manually setting to 16.9 and the picture size looked like it was zoomed in
    Help me :lease:
  2. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    I had some problems with aspect ratios when recording movies on Sky.
    In my case it was that the intro (the 20th Century Fox logo etc.) started in 4:3 and half way through went to 16:9.
    Check a few frames either side of the cuts you made to make sure they show 16:9 in the chapter edit screen, and check the intro section and the exit sections.
  3. the_Geezer
    the_Geezer
    Aug 12, 2004
    461
    +26
    for all the people that us SKY+ and a Tos SX32
    is the picture format on your sky+ box set to 4.3L , 4.3 , 16.9
