....I've just purchased a Hannspree Xv 37 inch TV and find that 'round is not round'.... !
The only correct screen aspect ratio where round is round and people look correct and not streched out wide - making them look short and squatty and fat in the face is the NORMAL (4:3) setting.
This however gives me a 3 inch black bar at the left and right of my screen and therefor defeats the reason to buy a widescreen television....
The PANORAMA mode is 'supposed' to keep the centre of the screen normal and stretch only the outer sides of the picture - thereby under 'most' circumstances will be hardly noticeable. The centre will look normal...This is what was on my previous CRT - 32inch widescreen JVC television and it worked very well...
If most programs (even the news) are now being broadcast in widescreen mode the 'NORMAL' should be widescreen with the correct aspect ratios and not a stretched 4:3 ratio.
Is my Hannspree 37 TV faulty or do other makes do this.. or are some 'panorama' setting on other maker sets more like my old JVC ???
I can't live with this and if this is 'normal' - i'll return the Hannspree and go back to my JVC.
ps. I work as a graphic designer and if I put out a moon or other round object in a piece of work and it got printed and looked oval my customers would go 'up the wall'.... why is this round problem (if it is the norm) not sorted OR do people simply not notice that the aspect ratio is not correct ???
