Aspect ratio corrected - finally!
dickst3
Established Member
Joined
Sep 15, 2005
Messages
544
Reaction score
Points
After 5 years of having the left and right hand side of our screen missing (chopping short credits etc!), thanks to lurking on this forum for a couple of weeks i have finally solved the problem. :thumbsup:
I had p*ssed around with the TV remote over the years thinking it was the TV but when I got the plasma i had to finally find a solution :lesson: a quick search here sent me in the direction of the Sky box which i found had not been set to 16:9!
So thanks forum! :clap: :clap: :clap:
I hope you set it to output RGB at the same time. :) :smashin:
Steve
What’s the difference?
RGB on mine makes the picture colours look too bright and cartoony and also the menu pages are les stable.
Steve
Yes, thanks. I haven't tried it without that setting so cannot comment! :)
must be your screen, RGB setting normally makes a big improvement
Set to RGB, and contrast LOW. Then readjust your screen if the colour looks off (or it may be that you've adjusted to crappy composite and forgotten what a good picture looks like LOL!!!)
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
