Aspect ratio confusion
Discussion in 'Projectors, Screens & Video Processors' started by Scoobycity, Dec 14, 2004.
  1. Scoobycity
    Scoobycity
    Dec 13, 2004
    34
    Hi there, I've just ditched my Rear projecton telly and ordered my first front projector. Its a Dell 3300MP which seemed a reasonable spec for the price I paid.
    Firstly, has anyone else had any experiance with one of these? They seem to be more aimed at the PC market rather than HC but apart from it having a native 4:3 I can't see any other problems.
    Secondly, Although I haven't recived it yet I'm making plans for the screen. I just want to get it up and running for the xmas season to start with so was planning on painting a panel with white emultion for now and get a decent screen later on.
    As its a 4:3 ratio projector does the screen need to be 4:3 or can I just zoom in so the borders will apear above and below the screen? Will the black bars be visable or will they blend with the surounding wall?
    I wasn't sure if this would be best off in the screens forum but this seems as much a projector issue as anything. :)
  2. moco
    moco
    Yes, you can zoom.
  3. AMc
    AMc
    Nov 20, 2000
    6,905
    Near Norwich
    +3,498
    From what I can gather the accepted advice is to build a screen the same aspect ratio as your projector.
    I have a 4:3 PJ and a 4:3 screen (made by canabilising a £20 IKEA blackout blind over a wooden frame). Works fine and means I can play PS2 games and watch footie VERY large.
    If you build a 16:9 screen you will only be able to use a very small area of the screen for 4:3 material (older films, TV shows, some games and some sports). Unless the extra height will be a problem then I'd recommend the 4:3 option.
    That said if all you're going to do is paint some MDF with Icestorm then you might want to splash out an extra £5 and try one of each. Won't cost you much more and will educate you for when you buy a 'proper' screen.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
  5. moco
    moco
    Simple solution: buy a pull-down screen (at 4:3 or square aspec ratio) and pull it down to different heights. A constant height mask (a black sheet) at the top will make it even better.
    Note: that most films are not 16:9. They are usually 2.35 or 1.85. This way you can always set the screen at the correct aspec ratio (limited by the fact that the roller does not stop at any point for manual screens).
  6. Scoobycity
    Scoobycity
    Dec 13, 2004
    34
    Thanks for the help :)
    So if was viewing a widescreen film on it would the top and bottom borders contain any light (even the top edges)?
    What I'm getting at is... would you be able to tell its a 4:3 projector?
  7. moco
    moco
    You would be able to tell, but if the areas out of the screen were black (or dark enough) it wouldn't be so disturbing.
