Aspect ratio and black bars on DVDs?
Discussion in 'Xbox Forums' started by screemer, May 2, 2007.
  1. screemer
    screemer
    Jul 7, 2004
    1,484
    48
    Southport
    +53
    I am using a VGA connection and when i play dvds the black bars at the top and bottom are bigger than when i use my stand alone dvd player? Is this right? Its a little off putting.
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,133
    Bristol
    +9,877
    I think it has something to do with VGA eliminating overscan.
  3. screemer
    screemer
    Jul 7, 2004
    1,484
    48
    Southport
    +53
    So it should have the bigger black borders?
  4. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    on most dvd's, yes, as theyre in a wider aspect ratio than 16:9, eg 2.35:1 being common in many films, which will have large black bars in any dvd player, and they may well be larger on vga than component due to the elimination of overscan.
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,133
    Bristol
    +9,877
    If you are connected via component then there will be overscan which will cut off some of the black bars but with VGA there is no overscan so you get 100% of what is on the disc.
  6. screemer
    screemer
    Jul 7, 2004
    1,484
    48
    Southport
    +53
    So basically that is how its supposed to be? VGA gives a better representation of the actual disc?
  7. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,133
    Bristol
    +9,877
    Correct
