Aspect ratio & 200 hours
Discussion in 'Plasma TVs Forum' started by suniil, Feb 27, 2005.
  1. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
    Hi All,
    apologies if this is repetitive!!
    I'm one of the new owners of pw7 panel and had around 20 hours running time. Bit concerned about DVDs 16:9 ratio, which leaves blank in top and bottom.
    Will that cause any problems?
    Thanks in advance
    N2P
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,123
    Galactica C.I.C.
    +350
    should be fine. The pw7 panasonic is very recistant to screen burn anyway, but keep the settings low for the first 150-200 hours. The only way you will get a problem with wide screen movies, is if that is all you are watching 24 hours a day, 7 days a week.
