aspect changing?
Discussion in 'Plasma TVs' started by GuitarGray, Jan 6, 2003.
  1. GuitarGray
    GuitarGray
    i have ordered my panny 42 v5 form richer sounds:)
    decided against a tuner at the time but now im not so sure. the panasonic shops tell me i cant change aspect ratio. IE panasonic auto just etc if i dont have a tuner ??
    also the conection problem s without 1 , i want to link video sky and dvd all exept sky only have 1 scart sky has 2.
    any ideas??
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    You can change the aspect ratio. Have a look at JS Tech's convertors that'll let you use the ports you need
    http://www.rgb2svideo.com/
    Neil.
  3. d_devani
    d_devani
    Simple issue
    Get a RGB to component converter from "rgbtosvideo" with the connecters.
    DVD Player scart > Sky scart
    Sky scart > JS Component converter scart
    JS Component converter component > Plasma Component
    Video composite/s-vid > Plasma composite/s-vid
    Sky RF out > Vid RF in
    This Component connection will also let u change the aspect settings and still keep the picture quality
    I got the below set up without the vid settings, but the dvd and sky quality is amazing.
  4. ddaddy
    ddaddy
    Nov 16, 2002
    92
    Hmmmm, I was going to order the RGB --> VGA converter when i get my pany. Which is better to get, rgb2vga or rgb2component?
    What are the benefits from one over the other, I will be using my pc through the screen, so keeping the vga input spare would be great.
    cheers
  5. GuitarGray
    GuitarGray
    mm ye thanks:) that dosnt sound too bad i think its 150 for the converters,
    will i then have full controll of aspect changing? like just mode and panasonic auto??
  6. d_devani
    d_devani
    for the best quality u would want the RGB --> VGA converter
    the rgb2component is suposed to be a very close second. The main advantage with the compnent converter is that u can change use different aspect modes which u cannot with the VGA converter also this will keep the VGA slot free if u wanna plug ur pc in.
    Personnally I like to fiddle around with different aspect modes so the component works well for me.. it does cost more than the VGA as well.
