ASK Impression A4+
stevegreen
I have been offered one of the above projectors for what i think is a reasonable price (£300)
Does anyone have any information on them? Would this be a decent projector for a first time user?
I am looking to project an image the size of around 8-9', would this projector do it from around 15' away?
As much info as possible needed.
Thanks guys!
stevegreen
Here is what i found on Projector Central
MSRP (USD) : **
Brightness (Lumens) : 750 ANSI
Contrast: ANSI: **
Full On/Off: 300:1
Weight: 5.0 kg
Size (cm) (HxWxD) : 13.7 x 24.9 x 29.5
Throw Dist (m) : 1.0 - 10.0
Image Size (cm) : 58.4 - 762.0
Lens: Focus: Manual
Zoom: Manual, 1.30:1
Optional Lenses: No
Digital Zoom: No
Keystone Correction: Fixed
Lens Shift: No
Compatibility:
HDTV: No
EDTV/480p: No
SDTV/480i: **
Component Video: No
Video: Yes
Digital Input: No
Personal Computers: Yes
Networking:
Wired: No
Wireless: No
Warranty: 2 Years
Lamp: Type:
150W UHE
Life: 2500 hours
Quantity: 1
Display: Type:
1.3" PolySi LCD (3)
Native: 800x600 Pixels
Maximum: 1152x870 Pixels
Aspect Ratio: 4:3 (SVGA)
Performance:
H-Sync Range: 14.0 - 100.0kHz
V-Sync Range: 44 - 130Hz
Pixel Clock: 150 MHz max
Speakers: 1.0W+ 1.0W
Max Power: **
Voltage: 100V - 240V
FCC Class: A
Audible Noise: 38.0 dB
Special: **
Status: Out of Production
First Ship: **
Last Ship: **
Can someone decipher this for me :confused:
hornydragon
Dpends how old it is how many hours on the bulb and how much a new bulb will cost also has it been used in a smokey environment? a S/H Z1 will be better for HC but cost more!
stevegreen
Ta mate,
Things that i need to know:
Will it produce a widescreen image? (it says 4:3)
Will I be able to connect up my DVD player, Xbox and Telewest box?
Checking on ProjectorCentral.com has confirmed that it will produce a large enough image for me but I have been told that this is classed as a 'Data Projector' and therefore is not ideal.
You may have guessed from the questions above that I really have no idea what I am talking about.
The crux of it all is, essentially, would it be a good idea to snap this up or should I maybe hang on for something better to come along. I see that a Panny A100 recently went in the classifieds for around the same amount of money, would this be better or worse than the Panny or something similar.
Thanks again
hornydragon
Without component video, its not looking good WS on a 4:3 PJ is like WS on a 4:3 TV thin image in the middle! if it will take RGB over the VGA might be ok but if limited to S-video or even composite then not worth it IMO mate! (guess it depends how badly you want a PJ and how much £300 will burn in your pocket).
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
