ASIO for foobar2000
Discussion in 'Desktop & Laptop Computers Forum' started by Triggaaar, Aug 31, 2005.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    From reading this forum, I understand that ASIO will allow my music to bypass the winXP kmixer, thus improving sound quality.
    Having just installed foobar, I'm now trying to download and set-up ASIO. I thought that it would come as a pluggin with Foobar2000 Special installer, but I could only find referrence to Kernal Streaming.
    Could someone point me to the most suitable download of the ASIO file(s) I need.
  2. The Dude
    The Dude
    May 21, 2004
    6,258
    Beverley, East Yorkshire
    +2,575
    this should do it... :)
    If you want to add ASIO support you can find a regularly updated ASIO plugin available here (just copy foo_output_asio(dll).dll into the components directory where Foobar is installed).
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    make sure you have a suitable soundcard as well to run this setup with
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Soundcard is M-Audio Audiophile 2496, which I see others using with Asio.
    Sorry to be stupid Dude, following that link, how do I get the pluggin? I've downloaded a file called 'foo_output_asio(dll)_047a.7z' and have no idea what to do with it. Did I choose the wrong link?
  5. The Dude
    The Dude
    May 21, 2004
    6,258
    +2,575
    copy it into the components directory? :D
    those instructions could be out of date, They're ones I grabbed from the web last year sometime... it's a while since I was running FooBar, Owain is an ASIO foobar user I think..... He'll tell you for sure when he checks back in... :)
  6. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    The file I've downloaded isn't a dll, its suffix is .7z
    Do I rename it, and then copy it? Or do I have to run a program with it?
  7. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    hi triggaar,
    maudio should work fine.
    took me ages to try and work that site out, in the end a kind forum member emailed me the zip file. No idea how you actually get it of the cypress site but I'll gladly email it on to you if you like.
    pm me your email if you do.
    owain
  8. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Genius, thanks
  9. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    All working, thanks guys.
    Had to change "output data format" to 32 bit (foobar -> preferences, playback) as I'd seen others do in previous threads.
    Now what shall I do :)
  10. The Dude
    The Dude
    May 21, 2004
    6,258
    +2,575
    Well, you've got everything working..... so how about some windows optimisation :devil:
  11. spamboy
    spamboy
    How about comparing the quality of kernel streaming to aiso? - it's supposed to do the same thing, bypass kmixer. I'm using it with my audiophile, but I'm unimpressed by the sound quality. I was wondering if I'd get an improvement going to aiso.
    Thanks,
    SB
  12. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Gald its all up and running :)
    what should you do now? Room EQ?
  13. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    It's frightening how little I know about all this. It's going to be a little while before I've run the cables to my plasma, so I'm not going to need to play with SPDIF for a while. What is there for me to optimise in the meantime?
    Let me get this right... you want me to install an inferior product, and test it, to see if it's worth you installing a superior product :) Installing ASIO took a minute once I knew what to do. I'll email you the DLL if you like.
  14. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    My PC isn't set-up for the living room yet. I'm happy with my meridian doing that, and it's set-up fairly well. PC will eventually be plugged in for the purpose of copying sky+ recordings, but I'm not wanting to use it as a dvd player.
    Getting sound sorted now for music and games. All other rooms have a squeezebox, but I didn't have a player for my flac files in my study.
  15. The Dude
    The Dude
    May 21, 2004
    6,258
    +2,575
    un-needed services, pointless never-used fonts, the crappy XP desktop theme that slows everything down... modding the hosts file to beef up security... ;)
    all sorts to look at if you have time to kill... they don't make a huge difference these days as CPUs are so fast.... but any system can be made a bit faster and safer if it's running a standard install of XP.... :)
    here's a good service tweaks page for you
    ( there are a few other good articles further down the page too.... )
  16. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    Cheers, I'll take a look. Be back when I've broken everything.
  17. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    If you want to do what the Dude says , and I suggest you don't unless you like wasting your time ;), get a copy of WinXPLite.
    This tool is awesome and will allow you to easily and safely strip the crap out of WinDoze. However, even with this tool, you realise that you can end up with a very non-functioning machine if yo take too much out, eg you really can kill IE, but it means you can never run Windows Update again so if your happy loading patches yourself or you won't change the machine or its not connected to the Internet then go ahead.
    Anyway its a seriously good tool which I uses when I want a really small WinXP build on say miniITX.
    www.litepc.com
    Rajiv
  18. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,026
    +1,135
    I think I'll give it a miss :)
    I'm not sure when I'll need all the processing power anyway - PC is mainly for music server, internet, and 2 games which don't require much (IL2 & GTR). It will also be for sky+ backup & replay (again, not that intensive).
