Not sure about a video club, will certainly research that. I am in Manchester
Well you could try my old club - Altrincham Movie Makers. They have a web site and are based on Park Road, Timperley. See if they "fit the bill"!
When I moved to North Wales, I lost any contact with a video club and I do miss the meetings.
£1000 is not a lot for a pro set-up. Have you any kit yourself? For a start from scratch:-
Camera. 4K consumer cam ~ £600. Professional camcorders cost around £1000-£2000 or more!
Mics. Example: BOYA 2 channel wireless mics £190 or wired tie clip mics
Tripod? £70
Extra SD cards, Batteries or power supplies for camera, mics and lights.
Lighting? Again will you need it? I use LED photofloods with batteries or a power pack. For a "pro" set-up, lighting is an advantage.
Possibly last (but definitely not least) a video editor for your PC.
This list is not comprehensive. For example mics could be wired into the camera or a table mic could be used.
Still on the technical side, you will need to consider how your final output will be presented. DVD, Blu-Ray, SD card, Cloud? Your own presentations to your customer audience?
Consider your (technical) process in three stages:-
1) Filming the subject. Do include cutaways to use as a transfer from one scene to another.
2) Editing the video into a coherent film with transitions, voice overs, music and effects.
3) Rendering the final edit into a form suitable for your presentation media.
Hope this helps.
