Artifacts on Sony Plasma, HDSTB and DVD
Discussion in 'Sony TVs Forum' started by soupratt, Apr 27, 2005.
  1. soupratt
    soupratt
    Just bought a SONY 42X1 HD plasma television and wow, the picture is amazing. I run the TEAC HD STB800 via DVI and DVD player (component to D15 plug). I have noticed that in there artifacts appearing especially in dark or fast moving areas. These are most noticeable in the HDSTB however it is also evident on DVD images. The pixels are small green/red that flash around the border of an image on the screen very briefly and dissapear (almost like ghosting or fizzing). Some programs are better than others but all show some artifacts at some stage.
    Here is a sample (notice around hand and bag).
    [​IMG]
    Any ideas. Is this normal ??? Initially I thought it was the STB however, as I noted earlier, they also appear on DVD movies but less so. Tried all the various colour/resolution modes (RCB,YUV DSUB, VIDEO, 1080,720,576) and all are the same.
    HELP !!!
    Andrei
  2. sdk
    sdk
    That is a little strange.
  3. dilsher
    dilsher
    summats very wrong - cos dat looks like a Tiny pic...
  4. sdk
    sdk
    Are they in the same spot always, cause it could be stuck pixels. But it looks like way to many of them.
  5. soupratt
    soupratt
    No, they flash on off in fast moving or darker areas.
  6. sdk
    sdk
    Then i have no idea what it is, might be something wrong with the panel. And is it just me or is there a pink tint on your picture? Might just be because you took a picture of it.
